| Peter's
Phantom Powered Condenser Microphone Pre-Amplifier
This is being hosted on behalf of Peter Miles
who designed this circuit for his church's sound system and used it for
the basis of a presentation on SPICE simulation at work. The pre-amp is
in regular use and has proved very reliable.
Words and circuit design by Peter Miles. Any
errors are likely to be mine!
An audio pre-amplifier designed to interface an electret condenser microphone
to XLR balanced microphone input at mixing desk which provides phantom
power.
Specification
- Bandwidth: suitable for good quality speech 100Hz – 10kHz ±3dB
- Gain: in range 12dB – 20dB
- Low noise
- Output impedance << 3kohms (to drive into 3kohms input impedance
at mixing desk).
- Transformer coupled balance output on to pins 2 & 3 of XLR audio
circuit.
- Powered from 48V phantom power coupled on to pins 2 & 3 of XLR
audio circuit via 6k8 resistors
- Provides DC bias in range 1.5V – 5V at input for the electret
microphone module.
- Construction: shielded inside metal box. Box to be grounded to pin
1 of XLR audio circuit.
Some
useful information on powering electret microphones
Schematic
schematic
datasheet for transformer
List of key items and sources
Item
Supplier |
Part Number |
Description |
| Veroboard |
Farnell
1201473 |
CIF AJB16 RBP STRIP PROTOBOARD 100X160 |
Copper clad plain board
Farnell
149054 |
KELAN PCB, PLAIN S/S 100X160MM |
| Box for system |
Farnell |
1171664 |
BOSS ENCLOSURES DIECAST BLACK Length / Height, external:62mm;
Width, external:112mm; Depth, external:31mm |
| JFET |
Farnell |
682366 |
ON SEMICONDUCTOR 2N5457 TRANSISTOR, JFET N TO-92 |
| Zener |
Farnell |
9844627 |
FAIRCHILD SEMICONDUCTOR BZX55-C5V6 DIODE, ZENER
500MW 5.6V |
| NPN Bipolar |
Farnell |
9558462 |
ON SEMICONDUCTOR BC182G TRANSISTOR, NPN TO-92 |
| XLR Cable |
Farnell |
4259348 |
LEAD, XLR MIC P-S 1.5M Connector A:3 Way XLR Plug;
connector B:3 Way XLR Socket; Length, lead:1.5m; |
| Transformer |
CPC |
LS01463
NTE4 NEUTRIK AUDIO TRANSFORMER-YELLOW |
Simulation Results
Simulations performed using Simetrix
Simulation
- Gain at 1kHz = 4.04mV / 500uV = 18.1dB
Measured performance on bench
- Vin = 12.3mV pk-pk
- Vout = 39mV pk-pk
- Gain = 39/12.5 = 3.12 = 9.9dB
Frequency Response |
Finished Assembly Photos
- Copper clad board on back of vero board to provide ground plane under
the entire circuit
- Circuit located inside diecast box by the copper clad board being
cut larger than the veroboard and providing tabs that slide into the
groves in the box inner walls.
