| GDT
Design Index Quick
Tips
Gate Characteristics
Half Bridge
Bi-Polar Drive
Primary AC Coupling
Saturation
Inductance
Leakage Inductance
Leakage + X-Conduction
Practical Design
Part Selection
SSTC Gate
Drive Transformer (GDT) Design Guidelines
Thanks go to Richie
Burnett for sharing his notes on SSTC design - credit is shared with
him for the content here, although any errors are most likely mine. If
you have any comments or corrections, please email me: james at pawson
dot plus dot com
This guide is primarily aimed at Solid State Tesla Coil builders, but
the notes apply equally to half/full bridge designs e.g. induction heating
applications.
Quick Start
- Quick Tips - A brief summary for those
that want to lash something up quickly. The rest of this guide is worth
a read, especially if you are new to SSTCs
The Theory
Practical GDT Design
- Practical design to reduce leakage
in a GDT
- Part selection
- Some existing designs have been added to this
thread on 4hv.org
- I've put some specific GDT construction notes on my Stubby
SSTC page
- I've made a basic GDT design spreadsheet in Excel
that allows calculation of the critical parameters, available for download
soon (.zip)
Driver Circuits
It should be noted that the GDT merely couples the drive power
to the gate of the transistor. As a result, whatever devices used to drive
the GDT primary need to be able to supply the high peak currents required
to rapidly charge and discharge the transistor gate.
MOSFET gate drivers are ideal for this task, such as the following devices
- Texas Instruments UCC37322
non-inverting and UCC37321
inverting drivers are the most popular choices, with a 9A peak drive
current capability.
- For the more difficult, higher capacitance IGBT gates, Ixys
make a selection of high current gate drivers, including the popular
IXDD414
- Maxim also make a selection
of gate driver ICs
For higher power drive of MOSFETs, although not entirely necessary, is
a half bridge of low voltage, high current small MOSFETs. Cross conduction
in these smaller transistors can occur if the gate drive circuitry is
badly designed. Steve Ward has an
example of this circuit.
Jan Wagner has some
good design
notes on SSTC gate drive design.
Further Reading
- This guide only deals with bipolar drive, AC coupled GDTs - the main
choice for half and full bridge SSTCs. For further information on different
gate drive configurations see http://focus.ti.com/lit/ml/slup169/slup169.pdf
- an excellent paper from Texas Instruments on high speed MOSFET gate
drive techniques. Page 30 onwards covers transformer coupled gate drive,
but the rest of the paper is well worth a read! It also covers driving
transistors with a signal that varies in duty cycle but that still requires
isolation
- This
page contains some info on basic magnetic principles and is worth
a read.
- This article
by Keith Billings discusses some aspects of high side gate driving
